tstamnas@yahoo.gr
March 18, 2025 at 9:27 am #1333
Mono path[0] = ‘C:/Nuro/World Builder/World Builder_Data/Managed’
Mono config path = ‘C:/Nuro/World Builder/MonoBleedingEdge/etc’
Input System module state changed to: Initialized.
[Physics::Module] Initialized fallback backend.
[Physics::Module] Id: 0xdecafbad
Initialize engine version: 6000.0.36f1 (9fe3b5f71dbb)
[Subsystems] Discovering subsystems at path C:/Nuro/World Builder/World Builder_Data/UnitySubsystems
kGfxThreadingModeSplitJobs is not supported on Direct3D 11. Reverting to kGfxThreadingModeClientWorkerJobs instead.
GfxDevice: creating device client; kGfxThreadingModeClientWorkerJobs
Direct3D:
Version: Direct3D 11.0 [level 11.1]
Renderer: NVIDIA GeForce GTX 1050 Ti (ID=0x1c82)
Vendor: NVIDIA
VRAM: 4004 MB
Driver: 32.0.15.6094
Begin MonoManager ReloadAssembly
– Loaded All Assemblies, in 7.316 seconds
– Finished resetting the current domain, in 0.003 seconds
[Physics::Module] Selected backend.
[Physics::Module] Name: PhysX
[Physics::Module] Id: 0xf2b8ea05
[Physics::Module] SDK Version: 4.1.2
[Physics::Module] Integration Version: 1.0.0
[Physics::Module] Threading Mode: Multi-Threaded
<RI> Initializing input.
Using Windows.Gaming.Input
XInput1_3.dll not found. Trying XInput9_1_0.dll instead…
<RI> Input initialized.
<RI> Initialized touch support.
UnloadTime: 0.464100 ms
DontDestroyOnLoad only works for root GameObjects or components on root GameObjects.
Starting World Builder 0.2.1
NullReferenceException: Object reference not set to an instance of an object
at WorldBuilder.Settings.SettingsSystem.Load (System.String filepath) [0x00030] in <643e4d3293834556b74c2774e5a142e0>:0
at WorldBuilder.Core.App+<Start>d__13.MoveNext () [0x0009d] in <8462592d85124d1d93d132bd129b1c6b>:0
at UnityEngine.SetupCoroutine.InvokeMoveNext (System.Collections.IEnumerator enumerator, System.IntPtr returnValueAddress) [0x00026] in <861a7d13d11f4169ab7691fd56fe10cd>:0NullReferenceException: Object reference not set to an instance of an object
at WorldBuilder.UI.UICreateProjectScreenController.Setup () [0x000a6] in <8462592d85124d1d93d132bd129b1c6b>:0
at WorldBuilder.UI.UICreateProjectScreenController+<Start>d__26.MoveNext () [0x0001a] in <8462592d85124d1d93d132bd129b1c6b>:0
at UnityEngine.SetupCoroutine.InvokeMoveNext (System.Collections.IEnumerator enumerator, System.IntPtr returnValueAddress) [0x00026] in <861a7d13d11f4169ab7691fd56fe10cd>:0RenderGraph is now disabled.
CommandBuffer: temporary render texture not found while executing (Copy source)
CommandBuffer: temporary render texture not found while executing (Copy destination)
[Physics::Module] Cleanup current backned.
Input System module state changed to: ShutdownInProgress.
Input System polling thread exited.
Input System module state changed to: Shutdown.March 18, 2025 at 8:42 am #1331Mono path[0] = ‘C:/Nuro/World Builder/World Builder_Data/Managed’
Direct3D:
Vendor: NVIDIA
VRAM: 4004 MB
– Loaded All Assemblies, in 0.136 seconds
– Finished resetting the current domain, in 0.002 seconds
UnloadTime: 0.441100 ms
Starting World Builder 0.2.0
at WorldBuilder.Settings.SettingsSystem.Load (System.String filepath) [0x00030] in <1ea35ea9f32643a8be4b796426ed9c83>:0
at WorldBuilder.Core.App+<Start>d__13.MoveNext () [0x0009d] in <6b223b282f62447a9a78ab3a7df089ca>:0
at WorldBuilder.UI.UICreateProjectScreenController.Setup () [0x000a6] in <6b223b282f62447a9a78ab3a7df089ca>:0
at WorldBuilder.UI.UICreateProjectScreenController+<Start>d__26.MoveNext () [0x0001a] in <6b223b282f62447a9a78ab3a7df089ca>:0
at MouseHandler+<Start>d__33.MoveNext () [0x00082] in <6b223b282f62447a9a78ab3a7df089ca>:0
at UnityEngine.SetupCoroutine.InvokeMoveNext (System.Collections.IEnumerator enumerator, System.IntPtr returnValueAddress) [0x00026] in <861a7d13d11f4169ab7691fd56fe10cd>:0[Physics::Module] Cleanup current backned.
Input System module state changed to: Shutdown.March 17, 2025 at 11:18 am #1327i reinstalled it into the unprotected folder “c:/Nuro/World Builder” and it didn’t work
