Currently not. If I understand you correctly, you would like to have an audio recorder which can stream the audio input to a speech-to-text AI which then passes this on to a LLM AI which can answer (as text or again as audio). Correct?
On our ToDo-List there is actually a similar setup planned for controlling the World Builder (Assistant) and, when done, we could open this feature to you in the form of a node or nodes in the Logic Editor.
Sometime early next year, we are also planning to finalize the dynamic scripting feature where you can add your own scripts and/or Nodes to the World Builder. This would enable to program a Node which does exactly what you want to do.
Currently, we launch an update every month, or better put, we launch an update when we feel we have something you guys could really use or even need which might be even more often than one a month.
