Some shortcut are not working
Welcome to Portals United! / Forums / Troubleshooting / Some shortcut are not working
  • January 14, 2025 at 2:02 pm #551
    Hello,
    I’ve noticed an issue with the undo functionality in the view, not working as expected. When I move an object and press Ctrl+Z to undo, the object does not revert to its previous position as expected. I suspect other keyboard shortcuts may also not be functioning properly also like ctrl+c and ctrl+v.
    Steps to reproduce:
    Select an object in the view
    Move the object to a new position
    Press Ctrl+Z
    Expected: Object returns to original position
    Actual: No change occurs
    Has anyone else experienced this issue? Any suggestions would be appreciated.
    Best regards
    January 16, 2025 at 10:25 am #553
    Yes, thank you. Undo is a known issue. However Copy and Paste should work just fine except in the Logic Editor which will be fixed in the next update. Undo will take longer.
