Empty Template missing in 2.0
Welcome to Portals United! / Forums / Troubleshooting / Empty Template missing in 2.0
- This topic has 5 replies, 3 voices, and was last updated 1 month, 1 week ago by
vfragk.
February 25, 2025 at 11:53 am #829
Can not create a new empty project in World Builder 2.0 because the Empty Template is missing. There’s no Empty Template on the marketplace either.
February 25, 2025 at 12:47 pm #830Does your WorldBuilder folder contain this path?
C:\Nuro\World Builder\World Builder_Data\StreamingAssets\Templates\Empty
(if that’s where you installed it)
“Empty” is the standard Template to create a new project. It should contain a “Project” folder and “Descripton.txt” as well as “Template_Banner.png”.
If this is not the case, you may want to first uninstall the WB and then run the installer again.
Having the same problem.
Unfortunately I’ve checked for “Empty” folder and exists at the path and also reinstall WB2.0 but nothing changed .
The menu is not loading the purchased templates from “XR4ED shop” (ex Demo Classroom or Minimalistic Demo Class that we used on 6November2024 meeting).
Although previous projects based on those templates can open.
February 26, 2025 at 1:45 pm #835We heard about this problem that the templates won’t show, but that was related to the “Empty” folder not being present. What you could do is post your log file after starting up the World Builder and after calling “New Project”.
The Player.log file is located in this folder:
C:\Users\<YOUR NAME>\AppData\LocalLow\Nuro\World Builder
February 27, 2025 at 11:02 am #842Hi Robert,
I’ve checked the folder with the Empty Template and all the files seem to be there.
Here’s the log file after trying to create a new project in the World Builder. I didn’t close the World Builder, I copied the content of the Player.log file with the builder still opened.
Mono path[0] = 'C:/Nuro/World Builder/World Builder_Data/Managed'
Mono config path = 'C:/Nuro/World Builder/MonoBleedingEdge/etc'
Input System module state changed to: Initialized.
[Physics::Module] Initialized fallback backend.
[Physics::Module] Id: 0xdecafbad
Initialize engine version: 6000.0.36f1 (9fe3b5f71dbb)
[Subsystems] Discovering subsystems at path C:/Nuro/World Builder/World Builder_Data/UnitySubsystems
kGfxThreadingModeSplitJobs is not supported on Direct3D 11. Reverting to kGfxThreadingModeClientWorkerJobs instead.
GfxDevice: creating device client; kGfxThreadingModeClientWorkerJobs
Direct3D:
Version: Direct3D 11.0 [level 11.1]
Renderer: NVIDIA GeForce RTX 3090 (ID=0x2204)
Vendor: NVIDIA
VRAM: 24325 MB
Driver: 32.0.15.6094
Begin MonoManager ReloadAssembly
- Loaded All Assemblies, in 0.114 seconds
- Finished resetting the current domain, in 0.002 seconds
[Physics::Module] Selected backend.
[Physics::Module] Name: PhysX
[Physics::Module] Id: 0xf2b8ea05
[Physics::Module] SDK Version: 4.1.2
[Physics::Module] Integration Version: 1.0.0
[Physics::Module] Threading Mode: Multi-Threaded
<RI> Initializing input.
Using Windows.Gaming.Input
<RI> Input initialized.
<RI> Initialized touch support.
UnloadTime: 0.390500 ms
DontDestroyOnLoad only works for root GameObjects or components on root GameObjects.
Starting World Builder 0.2.0
C:\Nuro\World Builder\World Builder_Data\Managed\Assembly-CSharp.dll
lib: C:\Nuro\World Builder\Plugins\External\myPlugin\myPlugin.dll
System.Reflection.ReflectionTypeLoadException: Exception of type 'System.Reflection.ReflectionTypeLoadException' was thrown.
Could not resolve type with token 01000011 from typeref (expected class 'IWizard' in assembly 'com.nuro.world-builder.plugin-core, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null')
at (wrapper managed-to-native) System.Reflection.Assembly.GetTypes(System.Reflection.Assembly,bool)
at System.Reflection.Assembly.GetTypes () [0x00000] in <eb0ef51e5908461ca908fdf6b2dbd966>:0
at WorldBuilder.Plugins.PluginProvider.AddPlugin (System.String libraryPath, System.Reflection.Assembly& assembly) [0x0002a] in <6b223b282f62447a9a78ab3a7df089ca>:0
System.TypeLoadException: Could not resolve type with token 01000011 from typeref (expected class 'IWizard' in assembly 'com.nuro.world-builder.plugin-core, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null')
RenderGraph is now disabled.
CommandBuffer: temporary render texture not found while executing (Copy source)
CommandBuffer: temporary render texture not found while executing (Copy destination)
Finished plugin [WorldBuilder.AssetManagement.PowerPoint.PowerPointImporter] setup with result: Succeeded
Finished plugin [WorldBuilder.AssetManagement.PDF.PDFImporter] setup with result: Succeeded
Finished plugin [WorldBuilder.AssetManagement.Model3d.Model3dImporter] setup with result: Succeeded
Finished plugin [WorldBuilder.AssetManagement.Images.ImageImporter] setup with result: Succeeded
Finished plugin [WorldBuilder.AssetManagement.BIM.IFCImporter] setup with result: Succeeded
Finished plugin [XR4EDPlugin.CYENS.XR4ED_CYENS_ArAppWizard] setup with result: Succeeded
Finished plugin [XR4EDPlugin.AssetManagment.XR4EDAssetsProvider] setup with result: Succeeded
Finished plugin [XR4EDPlugin.Publishing.XR4EDPublishingPlugin] setup with result: Succeeded
Finished plugin [XR4EDPlugin.Templates.XR4EDProjectTemplateProvider] setup with result: Succeeded
Finished plugin [NuroWorldBuilderPlugins.AssetCreation.MaterialCreator] setup with result: Succeeded
Finished plugin [NuroWorldBuilderPlugins.AssetManagment.LocalAssetsProvider] setup with result: Succeeded
Finished plugin [NuroWorldBuilderPlugins.AssetManagment.BuiltInAssetsProvider] setup with result: Succeeded
Finished plugin [NuroWorldBuilderPlugins.LocationView.ViewportTools] setup with result: Succeeded
Finished plugin [NuroWorldBuilderPlugins.InspectorViews.StandardInspectorViews] setup with result: Succeeded
Finished plugin [NuroWorldBuilderPlugins.Publishing.CostomPublishingPlugin] setup with result: Succeeded
Finished plugin [NuroWorldBuilderPlugins.Templates.TemplateExporter] setup with result: Succeeded
Finished plugin [NuroWorldBuilderPlugins.Templates.BuiltInProjectTemplateProvider] setup with result: Succeeded
Custom theme loaded: XR4EDTheme
Logged in as: boris.stajic@arvrtech.eu with id 2087
Login status changed: logged in is True
Curl error 7: Failed to connect to localhost port 80 after 2238 ms: Could not connect to server
Curl error 7: Failed to connect to localhost port 80 after 2243 ms: Could not connect to server
Here’s my log file when creating a new project with WB still opened
LOG file
Mono path[0] = ‘C:/Nuro/World Builder/World Builder_Data/Managed’
Mono config path = ‘C:/Nuro/World Builder/MonoBleedingEdge/etc’
Direct3D:
Renderer: NVIDIA GeForce RTX 3080 Ti (ID=0x2208)
Vendor: NVIDIA
VRAM: 12086 MB
– Loaded All Assemblies, in 0.123 seconds
– Finished resetting the current domain, in 0.002 seconds
XInput1_3.dll not found. Trying XInput9_1_0.dll instead…
UnloadTime: 0.399000 ms
Finished plugin [XR4EDWizardDemo] setup with result: Succeeded
Logged in as: vfragk@gmail.com with id 2112
C:\Users\vfragk\Documents\Projects\please enter your project name
NullReferenceException: Object reference not set to an instance of an object
at WorldBuilder.Core.ProjectManager.CreateProject (System.String projectName, System.String projectsDirectory, WorldBuilder.Core.ProjectTemplate template) [0x00025] in <6b223b282f62447a9a78ab3a7df089ca>:0
at WorldBuilder.UI.UICreateProjectScreenController+<>c__DisplayClass28_0.<Setup>b__3 () [0x0006c] in <6b223b282f62447a9a78ab3a7df089ca>:0
at UnityEngine.UIElements.Clickable.Invoke (UnityEngine.UIElements.EventBase evt) [0x0000b] in <a444ab25b405413c925b30e9b9ff2d49>:0
at UnityEngine.UIElements.Clickable.ProcessUpEvent (UnityEngine.UIElements.EventBase evt, UnityEngine.Vector2 localPosition, System.Int32 pointerId) [0x0009c] in <a444ab25b405413c925b30e9b9ff2d49>:0
at UnityEngine.UIElements.Clickable.OnPointerUp (UnityEngine.UIElements.PointerUpEvent evt) [0x0002f] in <a444ab25b405413c925b30e9b9ff2d49>:0
at UnityEngine.UIElements.EventCallbackFunctor`1[TEventType].Invoke (UnityEngine.UIElements.EventBase evt) [0x00010] in <a444ab25b405413c925b30e9b9ff2d49>:0
at UnityEngine.UIElements.EventCallbackRegistry+DynamicCallbackList.Invoke (UnityEngine.UIElements.EventBase evt, UnityEngine.UIElements.BaseVisualElementPanel panel, UnityEngine.UIElements.VisualElement target) [0x0008f] in <a444ab25b405413c925b30e9b9ff2d49>:0
at UnityEngine.UIElements.EventDispatchUtilities.HandleEventAcrossPropagationPathWithCompatibilityEvent (UnityEngine.UIElements.EventBase evt, UnityEngine.UIElements.EventBase compatibilityEvt, UnityEngine.UIElements.BaseVisualElementPanel panel, UnityEngine.UIElements.VisualElement target, System.Boolean isCapturingTarget) [0x00297] in <a444ab25b405413c925b30e9b9ff2d49>:0
at UnityEngine.UIElements.EventDispatchUtilities.DispatchToCapturingElementOrElementUnderPointer (UnityEngine.UIElements.EventBase evt, UnityEngine.UIElements.BaseVisualElementPanel panel, System.Int32 pointerId, UnityEngine.Vector2 position) [0x0000b] in <a444ab25b405413c925b30e9b9ff2d49>:0
at UnityEngine.UIElements.PointerEventBase`1[T].Dispatch (UnityEngine.UIElements.BaseVisualElementPanel panel) [0x00014] in <a444ab25b405413c925b30e9b9ff2d49>:0
at UnityEngine.UIElements.EventDispatcher.ProcessEvent (UnityEngine.UIElements.EventBase evt, UnityEngine.UIElements.BaseVisualElementPanel panel) [0x00053] in <a444ab25b405413c925b30e9b9ff2d49>:0
at UnityEngine.UIElements.EventDispatcher.Dispatch (UnityEngine.UIElements.EventBase evt, UnityEngine.UIElements.BaseVisualElementPanel panel, UnityEngine.UIElements.DispatchMode dispatchMode) [0x00046] in <a444ab25b405413c925b30e9b9ff2d49>:0
at UnityEngine.UIElements.BaseVisualElementPanel.SendEvent (UnityEngine.UIElements.EventBase e, UnityEngine.UIElements.DispatchMode dispatchMode) [0x0001f] in <a444ab25b405413c925b30e9b9ff2d49>:0
at UnityEngine.UIElements.VisualElement.SendEvent (UnityEngine.UIElements.EventBase e) [0x0000b] in <a444ab25b405413c925b30e9b9ff2d49>:0
at UnityEngine.UIElements.DefaultEventSystem.SendPositionBasedEvent[TArg] (UnityEngine.Vector3 mousePosition, UnityEngine.Vector3 delta, System.Int32 pointerId, System.Nullable1[T] targetDisplay, System.Func
4[T1,T2,T3,TResult] evtFactory, TArg arg, System.Boolean deselectIfNoTarget) [0x001bb] in <a444ab25b405413c925b30e9b9ff2d49>:0
at UnityEngine.UIElements.DefaultEventSystem+InputForUIProcessor.ProcessPointerEvent (UnityEngine.InputForUI.PointerEvent pointerEvent) [0x001ce] in <a444ab25b405413c925b30e9b9ff2d49>:0
at UnityEngine.UIElements.DefaultEventSystem+InputForUIProcessor.ProcessInputForUIEvents () [0x0006b] in <a444ab25b405413c925b30e9b9ff2d49>:0
at UnityEngine.UIElements.DefaultEventSystem.Update (UnityEngine.UIElements.DefaultEventSystem+UpdateMode updateMode) [0x0002f] in <a444ab25b405413c925b30e9b9ff2d49>:0
at UnityEngine.UIElements.UIElementsRuntimeUtility.UpdatePanels () [0x00067] in <a444ab25b405413c925b30e9b9ff2d49>:0
at UnityEngine.UIElements.UIElementsRuntimeUtilityNative.UpdatePanels () [0x0000a] in <a444ab25b405413c925b30e9b9ff2d49>:0 -
