Cannot start new WorldBuilder Version 0.2.0 anymore
Welcome to Portals United! / Forums / Troubleshooting / Cannot start new WorldBuilder Version 0.2.0 anymore
  • March 3, 2025 at 1:13 pm #858
    Hi, not sure what exactly happened but I can’t start the WorldBuilder anymore. It stucks before the Loading screen. After the update it was working the first time fine, but after inserting the sample dll nothing works anymore..
    No Login screen
    I tried the following:
    • Removed the sample DLL again (of course :D)
    • Reinstalled World Builder and Portal Hopper several times
    • Restarted the PC serveral times
    • Removed everything from the folder C:\Users\<user>\AppData\LocalLow\Nuro
    • According to the Player.log there is a null ref
    Player.log (last 4 lines):
    Finished plugin [NuroWorldBuilderPlugins.Templates.TemplateExporter] setup with result: Succeeded
    Finished plugin [NuroWorldBuilderPlugins.Templates.BuiltInProjectTemplateProvider] setup with result: Succeeded
    Custom theme loaded: XR4EDTheme
    NullReferenceException: Object reference not set to an instance of an object
    at WorldBuilder.UI.UIProjectsScreenController.BindProjectsList (System.Collections.Generic.List`1[T] projects, System.Int32 selectedIndex) [0x00114] in <6b223b282f62447a9a78ab3a7df089ca>:0
    at WorldBuilder.UI.UIProjectsScreenController.SetupOverview () [0x0037e] in <6b223b282f62447a9a78ab3a7df089ca>:0
    at WorldBuilder.UI.UIProjectsScreenController+<Setup>d__45.MoveNext () [0x00040] in <6b223b282f62447a9a78ab3a7df089ca>:0
    at UnityEngine.SetupCoroutine.InvokeMoveNext (System.Collections.IEnumerator enumerator, System.IntPtr returnValueAddress) [0x00026] in <861a7d13d11f4169ab7691fd56fe10cd>:0
    March 3, 2025 at 3:39 pm #859
    With first re-installing the old version (v0.1.36) and afterwards upgrading to v0.2.0 it works again.
    March 4, 2025 at 11:11 am #863
    This is a known issue and will be fixed with the next update.
    March 4, 2025 at 1:09 pm #867
    When can we expect this update? We cant use the WorldBuilder and we dont have access to the old version  (v0.1.36), and its not downloadable anywhere?
    March 4, 2025 at 1:23 pm #868
    The update will come end of this week. For the meantime, I added a link to World Builder 0.1.36 on this page:
    https://www.portalhopper.com/xr4ed/
