August 14, 2025 at 8:56 pm #1837
I can’t test this here without a working site to test it against. Since you have one, could you please send me the simple project you created via email? I hope to be able to determine then why it’s not working.
August 14, 2025 at 8:54 pm #1836Please send me or post here your link to one of the 2 vrml files, so I can have a look what’s going wrong.
August 13, 2025 at 10:43 am #1833Yes, I can see that it’s missing. You need to get registered as a vendor. Neofitos is your guy. 🙂
August 11, 2025 at 3:11 pm #1831The link should read https://xr4ed.cellock.com/product/list there, in the top right-hand corner you should see “Add Product”. Sometimes this button is outside of your screen and you may have to scroll to the right to see it. If you don’t see the Add Product button, then you may not have the right permissions. In that case please contact Mr. Neofitos Vlotomas from Cellock.
Otherwise click that button and you will be led to a create product screen. I think you see what to do there.
August 8, 2025 at 9:41 am #1829Sure. As the models are not created by the World Builder, the WB does not support an automatic upload. Instead, please go to the XR4ED shop directly, log in and upload your 3D assets there. The ‘native’ format of the WB is .glb, but it can also import other formats such as .fbx and .obj.
July 18, 2025 at 10:05 am #1821Please bring this topic to our meeting next Wednesday. We can stay longer at the end of the meeting and discuss the details. The SDKs on github have unfortunately not been updated for logistical reasons (access rights), but I can provide you with zip files which you can download. I don’t want to post the links here because they will become invalid soon. However, you may not actually need to download them depending on what you want to do exactly. But let’s discuss that next Wednesday.
The short answer is yes, you can create your entire project in the Unity editor and later adapt it to run in the Portal Hopper.
July 10, 2025 at 2:25 pm #1819We already discussed this by email but I just saw that you wrote “And I can use a Create VRML file option inside Unity for this, right?”. The answer, sadly, is no. The automatic VRML file generation is not up to date because we keep making changes and never have the time to update the VRML generator. To all who wish to
- use Unity and asset bundles with the Portal Hopper (PORTAL_HOPPER_PROTOCOL)
- launch an external app (installer) via the Hopper (DOWNLOAD_AND_RUN_PROTOCOL)
please contact me via email for further assistance.
July 8, 2025 at 5:50 pm #1817I’m sorry to hear that. However, did you try using the search box at the top of the Logic Editor page? It might be useful in such a situation, because it will jump directly to the selected node if you click on the found items in the drop down menu.
July 8, 2025 at 9:25 am #1815Unfortunately there currently is no way to place the user in a specific spot. The starting point is determined solely by the Start Avatar.
June 27, 2025 at 2:26 pm #1801I found the bug. The fix will come in the next Release (most likely Monday, 30th of June)
June 25, 2025 at 10:59 am #1797you can copy your projects to the new machine and reinstall the Portal Hopper and World Builder there. To share your work, place your project files into git.
June 25, 2025 at 8:35 am #1796I am pretty sure that xampp is case sensitive. This means that EmptyWorld.vrml and emptyworld.vrml are two different file names for xampp. Make sure, your spelling matches the folder name/file name exactly.
