Test Play
Welcome to Portals United! / Forums / Troubleshooting / Test Play
- This topic has 7 replies, 3 voices, and was last updated 2 months, 3 weeks ago by
December 18, 2024 at 7:52 am #489
I clicked the ‘Test button’ on the top left of ‘World Builder’ to test the logic, but it doesn’t go beyond the ‘Serialize World’ step. Is there any way to fix this?
Hopper is installed normally, and the path is also normal.
Also, the firewall is accessible.
I thought that the logic may have been wrong and caused an error, so I created a new project and tested it.
But it doesn’t work.
January 2, 2025 at 2:03 pm #516Did you install the hopper as well? If you install the portal hopper after the world builder, the WB may not find the hopper automatically and you need to enter the path to the hopper manually. Standard install path is “C:\Program Files (x86)\Nuro\Portal Hopper\Portal Hopper.exe”. You can change that under Settings/Tools/Hopper Path.
January 16, 2025 at 3:37 am #552Yes. I have installed the hopper and set the correct path for it. According to the documentation, I also configured the firewall access separately. However, it still does not proceed past the serialize world stage.
Is there something I might be missing? Are there any other conditions besides setting the hopper path and configuring the firewall access to enter test mode?
January 16, 2025 at 11:17 am #558You can try the following. Type hopper:http://reeldreem.de/vrweb/still.vrml into the address field of your browser. The hopper should launch and display a company profile world.
If the hopper does not start, then the hopper install failed or your operating system is blocking it from starting. If the hopper runs but it lands in our Central HUB world or in a room with vintage computers, then something is preventing the hopper from loading the vrml file from the net, perhaps a firewall or redirect of some kind.
let me know what you found out please, to the benefit of other users.
January 16, 2025 at 11:20 am #559To be clear, type in (or copy paste) the entire link including the “hopper:” which is not marked as a link in the previous message! I tested this on Chrome, FireFox and Edge.
I have the same problem. The hopper path is correct. When I try the to launch the test, the World builder stops before even trying to open the hopperas it stops at the ‘Serialize World’ step. By typing hopper:http://reeldreem.de/vrweb/still.vrml in the browser I am able to launch the hopper and I display the company profile world described.
January 19, 2025 at 4:19 pm #579When I access the link through my browser, I can start Hopper and see the described company profile world.
January 23, 2025 at 9:23 am #586It looks like there is a more general problem with your World Builder. You could send me your log file to figure out what is going wrong. To obtain the log file, open this path in the file explorer:
C:\Users\<YOUR LOGIN NAME>\AppData\LocalLow\Nuro\World Builder and send me the file called “Player.log”Please sent to robert.malzan@nuromedia.com, please don’t use my email to report bugs or questions.
