Run Time Scripting MyObritComponentTutorial
- This topic has 1 reply, 2 voices, and was last updated 1 week, 4 days ago by .
Welcome to Portals United! / Forums / Troubleshooting / Run Time Scripting MyObritComponentTutorial
Hi
From the documentation runtime scripting worked but the Orbit component is not working its there in the list I attached to to the object.
And also I Created new script and it is not being visible in components list to attach. The script and inspector files are in same folder.
Thanks
Many things may have gone wrong. I suggest you check the error output from the World Builder after each code import (press F12) to make sure the code compiled properly. Then, you need to restart the World Builder when you change any of the already imported code or folder with code (because the ‘old’ code is already bound to the World Builder).
If all else fails, you can post the code here and maybe we can figure out together what’s going wrong.
